ssam_138429's avatar
ssam_138429
Jan 03, 2018
Irule Help
Dears,
Need some help on the F5 configuration. The requirements are: 1.Do not apply URI redirect if the request is coming from a particular subnet. 2.Apply URI redirect otherwise.
Tried the below Irules its not working. Please help urgent.
when HTTP_REQUEST { if { ([HTTP::uri] equals "/") and ([IP::client_addr] != "10.1.2.0/24") } { HTTP::redirect "/cams" } }
when HTTP_REQUEST { if { [IP::addr [IP::client_addr] eq 10.1.2.0/24] } { return do nothing } elseif { [HTTP::uri] equals "/" } { HTTP::redirect "/cams" }
when HTTP_REQUEST { if { { [IP::client_addr] = "10.1.2.0/24" } } { return do nothing } else { HTTP::redirect "http://[HTTP::host]/cams" } }
Thanks & Regards, Sam
  • i think you had better also check uri.
    e.g.
      if { ![IP::addr [IP::client_addr] equals 10.1.2.0/24] and [HTTP::uri] eq "/" } {
    • ssam_138429's avatar
      ssam_138429
      No luck. I have tried enabling logging and found the irule is not detecting the ip address.
      when HTTP_REQUEST {log local0. "before ip" if { ![IP::addr [IP::client_addr] equals 10.1.2.0/24] and [HTTP::uri] eq "/" } { log local0. "after ip" HTTP::redirect "http://[HTTP::host]/cams" } }
      ssam_138429
      I am getting only the "before ip" in the logs. Seems like the if condition is not matching.
    e.g.
      ssam_138429
      ssam_138429
  • iRule provided by Nitass may work. I guess there is a nat device between the client and the F5.
    can you try this code to check client IP address (try to access to /myipaddress URL)
        if { ([HTTP::uri] equals "/myipaddress") } {
            HTTP::respond 200 content "
                    My IP Address
                    Your client IP : [IP::client_addr]
            " noserver
