Xylene_UK_11374's avatar
Xylene_UK_11374
Jun 29, 2009
IIS REMOTE_ADDR
Previously we had opened a case regarding the use of the Request.ServerVariable("REMOTE_ADDR") in ASP code. When we front our ASP sites with the LTM this Server Variable is changed to the a self-ip on the ltm. Since this code reference is pervasive we'd has preferred to not change it, but changing was certainly an option (undesirable nonetheless). However, we have discovered that we have a few vendor packages written in .NET and ASP that also use REMOTE_ADDR, and the issue is that we have no control over their code. We need to get a solution that will essentially substitute the client ip into the header so that it will be consumed by REMOTE_ADDR correctly. I was trying to work with the following iRule but I don't know what header value to change so that REMOTE_ADDR will pick it up.
HTTP::header replace REMOTE_ADDR [IP::remote_addr]
Also, we tried Layer4 Forwarding without any success. I think that the iRule should "fit the bill", but I have no idea what to replace. Is there a list of header values you pass from the LTM that we could look at so we can determine which one contains the self-ip which is subsequently pulled by REMOTE_ADDR?
