adam88's avatar
adam88
Icon for Cirrus rankCirrus
May 30, 2019
Solved
Difference between IP::client_addr and IP::remote_addr
I'm trying to create an iRule that inserts an X-Forwarded-For header based on the user's IP address, and I see that there are iRule examples that use IP::remote_addr while there are others that use IP::client_addr.
I can't seem to find a difference between these two commands, is there a difference?
