Prakin's avatar
Prakin
Icon for Cirrus rankCirrus
May 10, 2024
Maximum throughput of f5 ltm
is there way we can check the maximum throughput of the model via cli for hardware appliance and virtual editon as well?
    • Prakin's avatar
      Prakin
      Thanks, how about for the hardware platform?
  • Hi Prakin,
    You can try using tmsh to view throughput statistics
    Impact of procedure: Performing the following procedure should not have a negative impact on your system.
    Log in to tmsh by entering the following command:
    tmsh
    To view the current total throughput represented in bits and packets, enter the following command:
    show sys performance throughput
    You can add the historical option to also view 3 hour, 24 hour, 7 day, and 30 day historical increments by entering the following command:
    show sys performance throughput historical
    To view the current total TMM throughput statistics represented in bits and packets, enter the following command:
    show sys performance throughput detail
    show sys performance throughput detail historical
    Displays detailed throughput performance information in gigabits per second.
    show throughput gig detail
    HTH
    • Prakin's avatar
      Prakin
      Thanks for the detailed info, i am also looking for the maximum throughput supported by the hardware platform by design.
  • I looked up some of the it depends on what model and what setup   you have.  Did you have any in mind ?
    • Prakin's avatar
      Prakin
      actually i am looking for diff models that we have like 12800, i4800, 15800. is there anyway can we fetch the info from the CLI for the maximum throughput.
      • No there is no "limitation" by design. Its limited by the interfaces and hardware caps. Look up datasheet of your model.
        i-models are old! r-models are new!
