Herman2024's avatar
Herman2024
Jan 06, 2025
how does gtm/dns monitor wild-ip pool members?
hi, can someone please advise how gtm/dns monitor wild-ip pool members? what is the interval of probe ? I am running  tcpdump to capture the probe traffics, but nothing is captured after running tcpdump 30 mins. The tcpdump command is shown as below.
tcpdump -ni any host  10.10.20.21
10.10.20.21 is pool member (VS) IP address. This member status is shown online.
Please help to advise, thanks in advance.
    • Herman2024's avatar
      Herman2024
      Thanks Jeff_Granieri for your advice. The pool member is a Virtual server configured on a remote side LTM. This remote LTM and Wild-IP pool is learning through remote DNS/GTM which is in the same sync group. The doc you shared is about data center/server monitoring only, right? Regarding remote Wild-IP pool member monitoring, local DNS sends the probe directly to this pool member or get the pool member status via Sync group monitoring?
      Herman2024
      hi Jeff_Granieri , no prober pool is configured on our local DNS. And heath monitor is not configuration when click "Wild-IP" --> " Pool" --> click the pool" Pool xxx", under the field "Health Monitor" , no monitoring method is specified! This pool is learned via dns sync-group from remote DNS/GTM. Please advise how local DNS monitor the remote wild-ip pool status. Thanks in advance!
  • Global Traffic Manager (GTM)/DNS monitoring of Wild-IP pool members involves using various health-checking and monitoring techniques to ensure that IPs in a pool are responsive and able to handle traffic effectively. Wild-IP pools refer to IP pools where the exact identity of members may not be pre-defined or fixed, and they can dynamically change.
      Herman2024
      Thanks waqas34 for your advice ! Based on my description of our setup, what the method the local DNS uses to monitoring the remote wild-ip pool member ? The member IP is fixed, and tried to use tcpdump to capture the monitoring probe, but nothing was captured, don't know how locl DNS monitor the pool members. Please advise, if you need more info about our setup/config, I can provide, thanks in advance!
      Herman2024
      Thanks JoseLabra  for your kind advice. It seems we need to turn on the gtm debug , then know which dns/gtm is monitoring wideIP pool members, right? a bit complicated, please advise, thanks.
