baek1986's avatar
baek1986
11 years ago
How to check status of the console cable connection?
Do you know commands?
  • Are you asking how can you tell if someone is logged in to the console? I would run something like last and see if there are any ttyS0 logins (like the first line, especially if the last part says "still logged in").
    [root@bigip1:online:In Sync] config  last
    root    ttyS0                       Sat Nov 15 12:47 - 21:48 (31+12:37)
    root    pts/1   55.98.0.130         Fri Nov 14 18:52 - 22:16 (03:23)
    root    pts/0   c-57-161-249-108    Fri Nov 14 05:45 - 03:09 (1+21:23)
    root    pts/1   c-57-161-249-108    Tue Nov 11 19:53 - 05:03 (09:09)
    root    pts/1   55.98.0.130         Wed Nov 5 07:35 - 11:14 (03:39)
    root    pts/0   c-57-161-249-108    Wed Nov 5 06:20 - 21:10 (6+14:49)
    root    pts/0   55.98.0.130         Tue Nov 4 13:32 - 14:02 (00:30)
    • baek1986's avatar
      baek1986
      I would like to verify whether a physical console cable is connected or not. It is by no mean access records.
  • If the BIG-IP is connected to a console server I would run a script that would connect to the BIG-IP port on the console server, send some carriage returns and see if there is any output.
    If you are trying to figure out if someone is intermittently connecting a console connection to tamper with the F5 I don't know of any way to do this. Ultimately something like that would probably be easier to validate whether the person attempts to login to the BIG-IP
  • DEJ's avatar
    DEJ
    Hello B,
    The below will show you the status of the interfaces as well as statistical data. Was this what you were looking for?
    Via GUI: Statistics >> Module Statistics : Network : Interfaces
    Via CLI: tmsh show net interface
