Sulabh_Srivasta's avatar
Apr 30, 2021
Solved
Help for setting policy /iRule
Hello All,
I have a scenario where I have to use only one HTTPS Virtual server for multiple applications listening on different ports on different node, for example:
There are 3 servers , Node_X, Node_Y, Node_Z and VIP resolve to ww.abc.com
https://www.abc.com/core ----> https://Node_X:10004/core/
https://www.abc.com/service ----> https://Node_X:10004/service/
https://www.abc.com/ims ----> https://Node_X:10009/ims/
https://www.abc.com/portal ----> https://:Node_Y:10005/portal/
https://www.abc.com/ords----> https://Node_Z:10008/ords/
I created 4 pools as below but didn't attach any pool to the Virtual server:
Pool_X for Node_X - port 10004
Pool_X1 for Node_X - port 10009
Pool_Y for Node_Y - port 10005
Pool_Z for Node_Z - port 10008
I am using the following iRule but is is not working, please help how can I achieve this ?? Can I use policy or re-write policy ??
 if { [HTTP::uri] starts_with "/core" } {
    use pool Pool_X
  } elseif { [HTTP::uri] starts_with "/service" } {
    use pool Pool_X
} elseif } [HTTP::uri] starts_with "/ims" } {
    use pool Pool_X1
} elseif { [HTTP::uri] starts_with "/portal" } {
    use pool Pool_Y
} elseif { [HTTP::uri] starts_with "/ords" } {
    use pool Pool_Z
  • Hi Sulabh Srivastana,
    Remove use command.
    		pool Pool_X
    		pool Pool_X
    	} elseif { [HTTP::uri] starts_with "/ims" } {
    		pool Pool_X1
    		pool Pool_Y
    		pool Pool_Z
    switch version:
    	switch -glob [HTTP::uri] {
    		"/core*" -
    		"/service*" { pool Pool_X }
    		"/ims*" { pool Pool_X1 }
    		"/portal*" { pool Pool_Y }
    		"/ords*" { pool Pool_Z }
    without using pool:
    		"/core*" -
    		"/service*" { node 1.2.3.4 10004 }
    		"/ims*" { node 1.2.3.4 10009 }
    		"/portal*" { node 5.6.7.8 10006 }
    		"/ords*" { node 9.10.11.12 10008 }
    Remove use command.
    		pool Pool_X
    		pool Pool_X
    		pool Pool_X1
    		pool Pool_Y
    		pool Pool_Z
    switch version:
    		"/core*" -
    without using pool:
    		"/core*" -
  • Hi Enes,
    Thanks for your response, I tried but none of the given solution is working. Please let me know if I am missing something.
    • Enes_Afsin_Al's avatar
      Enes_Afsin_Al
      Icon for MVP rankMVP
      	log local0. "requri0: [HTTP::uri] - cip: [IP::client_addr]"
      		log local0. "requri1: [HTTP::uri] - cip: [IP::client_addr]"
      		pool Pool_X
      		log local0. "requri2: [HTTP::uri] - cip: [IP::client_addr]"
      		pool Pool_X
      		log local0. "requri3: [HTTP::uri] - cip: [IP::client_addr]"
      		pool Pool_X1
      		log local0. "requri4: [HTTP::uri] - cip: [IP::client_addr]"
      		pool Pool_Y
      		log local0. "requri5: [HTTP::uri] - cip: [IP::client_addr]"
      		pool Pool_Z
      Can you investigate the logs on cli and pool stats on gui?
      tailf /var/log/ltm | grep requri
  • I can see client IP as my IP (I am the tester) and SNAT IP, the iRule is being executed but traffic is not hitting the pool, no hits on pool.
