Willy's avatar
Willy
Dec 14, 2020
Solved
Setting default route using VLANs
We have a setup using more than one VLAN for the VIPs. This is functioning, but I would like to add default routes for each VLAN. Am I correct to create a route for each VLAN using the next settings ? Then I have the problem I can not add the gateway for that VLAN.
Description :
Destination : 0.0.0.0
Netmask : 0.0.0.0
Resource : Use VLAN /Tunnel
VLAN / Tunnel : vlanA
MTU : 0
Main question are :
  1. Do I need the default route for each VLAN or can I count on the "Auto Last Hop" function ?
  2. If yes, how to create the default route for each VLAN using the gateway in that VLAN ?
  • Hello Willy,
    You're welcome. If my answer was helpful, please don't forget to tag it as 'the best' to help other people to find it.
    Regards,
    Dario.
  • Hello Willy.
    Only configure one single default route for generic traffic and let "Auto Last Hop" feature to work for the rest virtuals located in the rest of VLANs.
    REF - https://support.f5.com/csp/article/K13876
    Regards,
    Dario.
    • Willy's avatar
      Willy
      Hello Dario,
      Thank you for confirming the auto last host feature and the extra info.
      Kind Regards,
      Willy
  • Hello Willy,
    Regards,
    Dario.
    • Willy's avatar
      Willy
      Hello Dario,
      I did select the best just a moment ago.
