cxcal_18687's avatar
cxcal_18687
Jun 20, 2011
Failing Hard Drive
Looking to shed a little more light on a suspected hard drive issue.
DataCenter Engineer said the F5 LTM has a blighting light complaining about a hard drive failure.
I don't show anything on the system (unless I'm looking in the wrong place)
Can someone direct me to some useful documentation to help determine if there is a hard drive problem.
Thanks for the help!
  • hoolio's avatar
    hoolio
    You could check /var/log/ltm for bad sector or other HDD related errors. Or you could run the End User Diagnostic to check definitively.
    Aaron
  • have u checked /var/log/kern.log? hdd error is usually shown there.
    additionally, eud may not contain fsck. it depends on what eud version u r using.
    sol11664: Change in Behavior: Removal of File System Check from the EUD
    http://support.f5.com/kb/en-us/solutions/public/11000/600/sol11664.html
    hth
  • Yes EDU will help you to find out where the problem exactly is....
  • Can a filesystem check be performed remotely or does it require you to connected to via console in single user mode?
  • hoolio's avatar
    hoolio
    Only in single user mode as the drive needs to be unmounted:
    sol10328: Forcing a file system check on the next system reboot
    http://support.f5.com/kb/en-us/solutions/public/10000/300/sol10328.html?sr=15095806
    Aaron
  • Can someone explain what the "undefined" indicates?
    Sys::Raid::Disk
    Name Serial Number Array Member Array Status
    CF1 CB06537260500900RY05 no undefined
    HD1 WD-WCAT1E936493 yes ok
    HD2 WD-WCAT1E937650 yes ok
    Running v10.1.0
  • hoolio's avatar
    hoolio
    That's just showing that there isn't a RAID array defined for the compact flash. I see the same thing on a working 8900:
    Sys::Raid::Disk
    CF1   B85131BGBCR209131600  no            undefined
    HD1   WD-WCAT18687337       yes           ok
    HD2   WD-WCAT18687750       yes           ok
    Which platform is this? Have you seen SOL12170:
    sol12170: The BIG-IP system may use the CompactFlash card for the swap partition on some platforms
    http://support.f5.com/kb/en-us/solutions/public/12000/100/sol12170.html
    You could force an disk check following SOL10328. You might also try running qkview and uploading the tech.out to http://ihealth.f5.com to review the suggestions there. If you don't get anything useful there, you could open a case with F5 Support.
    Aaron
