Jad_Tabbara__J1's avatar
Jad_Tabbara__J1
May 16, 2019
Solved
Does F5 encrypts traffic internally from a VS to another VS ?
Dear community,
Context
VS_Parent with clientssl + serverssl profiles and an iRule (that is responsible for routing the traffic to the child VSs based on the FQDN for example)
VS_Child1  has clientssl + serverssl profiles
VS_Child2 has clientssl + serverssl profiles
All VSs are on the same BIGIP.
Client < Encrypted Channel 1 > VS_Parent < Encrypted Channel 2 > VS_Child1 or VS_Child2 < Encrypted Channel 3 > Pool_Member
Question
Based on the theory, the BIG-IP should have 3 encrypted channels
To confirm that, I've done a "tcpdump" on the child VS to see if the traffic is encrypted. I can't see any SSL packet using Wireshark.
Does F5 encrypts traffic routed from a VS_Parent to a VS_Child ? Or it doesn't encrypt it, in order to optimize resource utilization ?
Thanks for your help
Jad
  • Hi Jad,
    I had already asked myself the question.
    So Yes, F5 encrypts traffic routed from a VS_Parent to a VS_Child.
    I validate my supposition by removing SSL Client in VS_Child  and noticed that access to my service was not functional.
    Additional you can use my Debug irule (hosted in devcentral) that allow you to see that Cipher/protocol used in both VS (Child an parent).
    I advise you to process a ssldum using this kb:
    https://support.f5.com/csp/article/K10209
    So in child vs, initiate a basic capture:
    tcpdump -vvv -s 0 -nni external -w /var/tmp/www-ssl-client.cap host 10.1.1.100 and port 443
    then check ssl exchange:
    ssldump -nr /var/tmp/www-ssl-client.cap
    keep me in touch.
    regards,
  • Hi Jad,
    keep me in touch.
    regards,
    • Jad_Tabbara__J1's avatar
      Jad_Tabbara__J1
      Hello Youssef,
      Thanks for your answer. Using the "tcpdump + ssldump" I can see the SSL Handshake on the VS_CHILD...
      Before posting my question, I've done same capture using tcpdump, but I used Wireshark to see the SSL Handshake.
      My wireshark was not parsing the SSL traffic correctly, indeed using my colleague Wireshark we can see the SSL Handshake. I will re-install my wireshark to correct this.
      So the issue come from my wireshark :D
      Thank you you helped me to answer 2 questions in one :p
      Regards
  • Hello Jad,
    Glad to have been able to bring you my help my dear.
    Regards
