suthomas1's avatar
suthomas1
Mar 09, 2021
Solved
connection stickiness
Good day all,
After traffic passes through a virtual service, what is the best way to check upon stickiness/persistence for those connections.
or for any checks after these stickiness configuration has been amended, is there a way to verify the connections are keeping those persistence.
Thanks in advance.
  • If this is what you are referring to...from TMSH
    show ltm persistence persist-records <virtual server name you want to check persistence>
    -And for UIE persistence-
    show ltm persistence persist-records mode universal <virtual server name you want to check persistence>
  • ant77's avatar
    ant77
