John_Ogle_45372's avatar
John_Ogle_45372
Jul 25, 2011
call a sh script from within an existing script
I have an external monitor (sh script) that runs a program that calls a another sh script to run and then looks for the results.
It work fine from the cli but not when I configure it as an external monitor. Is there something I need to do to have the LTM allowed to run the external script?
I verified with tcpdump that the external monitor (sh script) only works when I remove the option/portion that calls on the additional script to run.
any help is REALLY appreciated.
  • Can you try to put absolute path to all command? If it's ok, you can also post your scripts here after removing confidential data.
