Luca_55898's avatar
Luca_55898
Nov 29, 2011
backup script help
hi Guys,
Need some assistance getting a backup script to work from a linux box.
here is the script, its pretty simple:
set host sydipreflb01
spawn ssh root@$host
expect ""
send "b config save /config.ucs\r"
send "scp /config.ucs root@jenkins:/var/lib/jenkins/backup/F5/sydipreflb01-`date +%d_%m_%y`.ucs\r"
I have shared SSH keys and all that works.
When the script runs, it logs onto the F5, sits there for about 2 seconds then just exits without executing the b config save and scp commands.
If i remove the 'send' from the script i get errors saying
"Active] config invalid command name "b config save /config.ucs
while executing
""b config save /config.ucs\r""
Any thoughts?
