Technical Forum
Custom Alert Banner
XFF replace iRule help
dinodell4477
How would I go about replacing the X-Forwarded-For header with a value from another header such as "Real-Client-IP" for example. Something like the below is what i'm statrting with but this obviously isnt working.
HTTP::header replace X-Forwarded-For HTTP::header value Real-Client-IP [HTTP::header value X-Forwarded-For]
Thanks in advance!
1 ACCEPTED SOLUTION
Hello Tetimmons.
Try this:
   HTTP::header replace X-Forwarded-For [HTTP::header value Real-Client-IP]
   HTTP::header remove Real-Client-IP
Regards,
Dario.
2 REPLIES 2
Hello Tetimmons.
Try this:
Regards,
Dario.
dinodell4477
Thanks all!
