29-Jan-2021 01:17
I have configured to redirect Virtual server to maintenance page when all pool member down.
I have configured below guide:
https://support.f5.com/csp/article/K14702105
When i used irule below, Irule has completed configuration.
if { [active_members [LB::server pool]] == 0 } {
HTTP::respond 200 content "
<html>
<head>
<title>Maintenance Page</title>
</head>
<body>
We are sorry, but the site you are looking for is temporarily out of service.
If you feel you have reached this page in error, please try again.
</body>
</html>
But, when I edited as below, irule has not change:
<html>
<head>
</head>
<body>
<article>
<center><h1 style="color: #000;">
Xin lỗi quý vị, hệ thống đang được bảo trì. Xin quý vị quay lại sau khi bảo trì hoàn tất.</h1> <center>
<div>
<center><h1 style="color: #000;">Xin trân trọng cảm ơn!.<p></p><center>
</center></h1></center></div>
<article>
</body>
</html>
Errors as below:
Pls guide me!
29-Jan-2021 02:55
Hi
Try changing the " " to group the HTML to { } braces instead as per the error. Suspect the " in the style lines are causing a conflict.
HTTP::respond 200 content {
<html>
<head>
</head>
<body>
<article>
<div>
<article>
</body>
</html>
31-Jan-2021
20:19
- last edited on
24-Mar-2022
01:12
by
li-migration
Thanks for ,
I changed belong as you. But irule failed.
01-Feb-2021 04:17
OK - so you could either move your html code to a variable and then make a call to it like this
when RULE_INIT {
set static::sorry_code {
<html>
<head>
</head>
<body>
<article>
<div>
<article>
</body>
</html>
HTTP::respond 200 content $static::sorry_page
...or you could try moving the html code to an iFile - https://clouddocs.f5.com/api/irules/iFile.html - if there are any strange characters in the html code that is causing a conflict then this method should resolve these issues
