Technical Forum
Source IP for SNMP traps
Bartek
Cirrus
Cirrus
Hi Guys,
I can't find it anywhere - what is the source IP for SNMP traps when you configure the network to "Default"? I'm having a HA setup of two 12.1.5 devices.
4 REPLIES 4
Hello,
What do you see under " show running-config sys snmp trap-source"
F5 can use different outgoing interfaces to send snmp traps. You can even modify and configure source interface as per your requirement for snmp traps. Please refer below article.
https://support.f5.com/csp/article/K91608713
Hope it helps!
Mayur
Samir
MVP
MVP
Did you try tcpdump to check source ip?
tcpdump -i any -nn port snmp
​hope it will work for you..
Bartek
Cirrus
Cirrus
The source is set to "default" in trap configuration - can't really find a definition of "default".
Tcpdump was one of my first ideas, however hard to track the source when traps are not firing that often.
Do you have any specific host route for SNMP server or is it using default route to reach it from F5? I think, unless SNMP server is a connected network, it would use the interface to go to server where the default route is pointed.
Mayur
