Technical Forum
Custom Alert Banner
Priority group activation and automatically closing connections when higher priorty group goes UP.
Asura2006
Altocumulus
Altocumulus
Hello we have a configuration where in one pool there are 6 nodes with 2 priority groups of 3 nodes each.
3 nodes with piriority group 1 (backup)
3 nodes with priority group 10 (primary).
Priority group activates when there are less than 2 active members on primary group.
So far It works like it should.
But we would also need to:
1) close all connections to the backup PG when the primary PG becomes available again,
2) it would be great to create a delay/timer of 2-3 min from the time primary PG goes up and time of closing all the connections in the backup PG.
We have achieved something similar using HA proxy using below configuration, but we would like to have this functonality on F5 LTM:
server rabbit1a <ip addres>:5671 check send-proxy inter 3s fall 3 rise 2 on-marked-up shutdown-backup-sessions
server rabbit2a <ip addres>:5671 check send-proxy inter 3s fall 3 rise 2 on-marked-up shutdown-backup-sessions
server rabbit3a <ip addres>:5671 check send-proxy inter 3s fall 3 rise 2 on-marked-up shutdown-backup-sessions
server rabbit1b <ip addres>:5671 check send-proxy backup
server rabbit2b <ip addres>:5671 check send-proxy backup
server rabbit3b <ip addres>:5671 check send-proxy backup
Is it possible on F5? I guess its not something that we can achive from pure GUI so we would need to use iRules? What events/actions would be usefull in this case?
12 REPLIES 12
Hi @Asura2006 ,
The default behavior of Priority group Activation is when the Backup PG activated it handles your connections , but when higher PG is returned UP and active again , all comming new connections is handled by "main" PGA and the Backup PG handles only Active connections till it completes.
I see this is a good behavior to be done by PGAs and this is the default.
If you see that the new connections don’t be handled by "main" PG when it became actve , check if you enable " manual resume " option under assigned monitor configuration.
> Do you want to transfer active connections to be handled by "main"PG when it became available again ?
specify more please in this section.
Regards
_______________________
Regards
Mohamed Kansoh
Hello,
the problem here is that i want primary PGA to handle ALL the connections after 2-3 minutes from beeing back up. The connections on backup PGA should be closed so that they will be all on primary PGA.
Manual resume on monitor doesn't really help me because it means that each time the primary PGA goes down and up ill have to manually select "enabled" to every node with this monitor.
@Asura2006 ,
Do you configure any type of persistence profiles ?
the default behavior , your new connections should be handled by "main "PGA when it becomes available, only Active connections should be handled by the "Back up" PGA till complete.
Regards
Mohamed Kansoh
Kai_Wilke
MVP
MVP
Question to your scenario: Do your application have to maintain a server side session state which require the use of what F5 is calling "Session Persistence", or are your application absolutly fine if request from the same client is per-request load balanced to the available online nodes?
Depending on the requirement of persistence, you would either need to create a GUI based setup via OneConnect (to enable per-request balacing) and Pool- and Monitor-Settings. Or you may end up with a custom iRule to handle the closing of such persistet sessions if your primary/backup systems are failover/fallback.
Cheers, Kai
iRule can do… 😉
Right now there is no requirement for persistance so i guess we will have to use the OneConnect profile pool and monitor setup? But i don't see how it is going to delete the connections for backup PGA after the priority PGA will become active.
In one connect program there is a  maximum Age time but I dont know if I should set it to something like 2-3 minutes. Wouldnt it defeat the purpose of OneConnect profile ?
One Connect Profile will completely detach the client-side TCP connection from your server-side connections, so that your dont have to care about already established connections. Each incomming client-side HTTP request will be load balanced (based on Pool-Priority-Groups availibilites) and then use a pooled service-side connection to the individial members.
OneConnect enables you to switch between Pool-Priority-Groups without closing the client-side connection, the very next HTTP request will be load-balanced to the Master/Fallack Priority-Group as needed.
If applying a OneConnect Profile to your Virtual Server is not a problem, then you can continue to use your single Pool setup including Priority-Based Activation. The only change needed would be to adjust your Health-Monitors, so that a node will delay a state change to UP for 2 minutes (via "Time Until Up" setting).
Let me know if you need further assitance to get the OneConnect setup running.
Cheers, Kai
iRule can do… 😉
Hey @Asura2006  - if Kai's response solved your issue, could you please hit the Accept as Solution button, so future users dealing with the same problem can easily find the solution to their issue?
Hello,
to be honest i have to test all the potential solutions presented here in ths thread and ill get back as soon as i test it
Especially the one that xuwen wrote below because it needs a little bit of configuration on my side.
xuwen
MVP
MVP
To meet your needs, you must use icall and user_ alert.conf
pool_server has 6 pool members,  (A,B,C) group priortity is 10; (D,E,F) group priority is 5:
ltm pool pool_server {
    members {
        192.168.100.1:telnet {
            address 192.168.100.1
            priority-group 10
            session monitor-enabled
            state up
        192.168.100.11:telnet {
            address 192.168.100.11
            priority-group 5
            state up
        192.168.100.12:telnet {
            address 192.168.100.12
            priority-group 5
            state up
        192.168.100.13:telnet {
            address 192.168.100.13
            priority-group 5
            state up
        192.168.100.2:telnet {
            address 192.168.100.2
            priority-group 10
            state up
        192.168.100.3:telnet {
            address 192.168.100.3
            priority-group 10
            state up
    min-active-members 2
    monitor tcp
The master member has A, B and C(firstly create a icall_pool its pool member is A,B,C). You also have to create three pools (pool_icall-1, pool_ical-2, and pool_icall-3). The members are (A, B), (A, C), and (B, C) respectively
pool_back members is (D,E,F)
user_alert.conf
alert poolicall-1-DOWN "No members available for pool /Common/pool_icall-1" {
        exec command="tmsh generate sys icall event delete_backserver_session context { { name poolname value pool_ic
all } }"
alert poolicall-2-DOWN "No members available for pool /Common/pool_icall-2" {
all } }"
alert poolicall-3-DOWN "No members available for pool /Common/pool_icall-3" {
all } }"
When any of the pools has no available members, an icall event is triggered. Execute the exec linux shell in the icall script (icall script is based on tcl and wants to sleep for 120 seconds, and then execute the session action of deleting the standby node. Later, the test found that icall script deleted the after xxx ms {script} function of tcl, and cannot execute the after function. Instead, we call  use exec linux shell
#!/bin/bash
#sleep 120;
count=`tmsh list ltm pool pool_icall | grep "state up" | wc -l`
if [ $count -ge 2 ]
then
        for i in `tmsh show ltm pool pool_back members | grep -E "Ltm::Pool Member:" | awk '{print $NF}'`
        do
                address=`echo $i | awk -F ":" '{print $1}'`;
                port=`echo $i | awk -F ":" '{print $2}'`
                tmsh delete sys connection ss-server-addr $address ss-server-port $port
        done
fi
 icall config:
list sys icall handler triggered delete_backserver_session
sys icall handler triggered delete_backserver_session {
    script delete_backserver_session
    subscriptions {
            event-name delete_backserver_session
list sys icall script delete_backserver_session
sys icall script delete_backserver_session {
    app-service none
    definition {
        foreach var {poolname} {
            set $var $EVENT::context($var)
        puts "poolname is $poolname"
        exec /bin/bash /var/tmp/delete_backserver_session.sh
    description none
    events none
xuwen
MVP
MVP
pool_server has 6 pool members,  (A,B,C) group priortity is 10; (D,E,F) group priority is 5, tcp monitor use "tcp_delay_up_120s" and its value of "Time Until Up"  set 120s;
pool_icall members is (A,B,C), use default tcp monitor
pool_back members is (D,E,F), use default tcp monitor
user_alert.conf
alert poolserver-1-UP "Pool /Common/pool_server member /Common/192.168.100.1:23 monitor status up" {
all } }"
alert poolserver-2-UP "Pool /Common/pool_server member /Common/192.168.100.2:23 monitor status up" {
all } }"
alert poolserver-3-UP "Pool /Common/pool_server member /Common/192.168.100.3:23 monitor status up" {
all } }"
 icall config:
    subscriptions {
    app-service none
    definition {
    description none
    events none
chmod +x /var/tmp/delete_backserver_session.sh
#!/bin/bash
if [ $count -ge 2 ]
then
        do
        done
fi
Thanks for this very detailed answer, when i implement it on test environment ill get back to you.
One thing about the script delete_backserver_session.sh also configuration in user_alert.conf and icall config what about maintaining them? Will they be automatically migrated during software upgrade or ill have to remember about them and copy them every time i do upgrade?
xuwen
MVP
MVP
Because the 120 seconds delay depends on tcp monitor use "tcp_delay_up_120s" and its value of "Time Until Up" set to 120s. You can use tcl script tmsh:: delete to delete a session. The Linux shell is not mandatory
the file in /config/  directory will save in ucs,user_alert.conf and icall config also save in ucs file
In my test environment, six Cisco routers enable the telnet service, a bip IP VE. When I close the telnet service of the three primary nodes, and then the client telnet VS, I manage the router of the backup node, and then enable the telnet service of the primary node to simulate the recovery of the primary node. During the 120 seconds, I execute the show running command. After about 120 seconds, I will be reset tcp connection
