07-Oct-2021 02:09
I have VS which listen to port 443 and 80 , mapped to pool which listen to rang of port ex 1000 - 2000
in this case i have create pool with * services port ( any) and associated with i rule. Does the below correct?
TCP::local_port is the correct one? or not?
when CLIENT_ACCEPTED {
if { [TCP::local_port] => 1000 and [TCP::local_port] <= 2000 } {
return
else {
reject
13-Oct-2021 02:04
on serverside session (SERVER_CONNECTED) [TCP::server_port] command returns the pool member port.
But your setup won't work in my opinion because VIP should be listening on wildcard port, if you wish to send the traffic to pool member on wildcard ports and incoming traffic should come on the target port of the server to F5.
