E_Lenny_Brown_1
Dec 17, 2003Nimbostratus
POOL_VS enable after manual resume disables.
I have my 3dns set to manual resume when it detects a failure on a virtual server. When the VS comes back up I would like to enable it via a perl script. Unfortunately, the enable_virtual_server() in BaseServer will not enable it. I get no errors, just no enabling. I can disable via disable_virtual_server() and the enable works great.
The biggest difference I see is that in the 3dns GUI, it shows the object type as VS if disabled vi icontrol or the gui, and POOL_VS if disabled by manual_resume.
What am I missing?
Thanks,
Lenny Brown
lenny.brown@metro1.com
