Abhilash_37247's avatar
Abhilash_37247
Aug 08, 2014
Need suggestion on how to resolve the issue with a TCL error happening due to a HTTP::respond in another irule attached to the same Virtual Server
Hi, We have a virtual server which has four irules configured on it. The irule(irule) with the highest priority has a logic which would perform a HTTP::respond during the HTTP_REQUEST event with a status of 503 back to the client if the IP address matches one that is part of a configured blacklist of IPs specified in a datagroup. There is another irule(irule2) that is of lower priority that has a logic to remove a header and add it with a different value. HTTP::header remove testHeader HTTP::header add testHeader testvalue
What we are observing is that there are errors during the irule execution with stack trace as follows. 2014 Aug 8 11:48:54 server name local0 err err tmm1[4798]: 01220001:3: TCL error: irule2 - Operation not supported (line 1) invoked from within "HTTP::header remove "testHeader""
We have been looking at different threads in DevCentral and found the following links that were helpful.
https://devcentral.f5.com/questions/how-to-disable-irule-processing-on-keep-alive-per-request-when-using-httprespond https://devcentral.f5.com/wiki/irules.drop.ashx https://devcentral.f5.com/wiki/iRules.detect_prior_http_redirect_or_respond.ashx
We would like to know if performing drop after HTTP::respond in irule1 is a good practice. Additionally we would like to know what is the suggestion of a good practice for the solution in this scenario.
Thanks and Regards, Abhilash
  • Hi - You just need to issue "event HTTP_REQUEST disable" to prevent further iRule processing.
    I don't think issuing a 'drop' after HTTP::respond would help - pretty sure you'd still get a TCL error, and in addition it might not send the response
  • There is another irule(irule2) that is of lower priority that has a logic to remove a header and add it with a different value. HTTP::header remove testHeader HTTP::header add testHeader testvalue
    another approach is to move rule2 to HTTP_REQUEST_SEND event.
  • e.g.
     config
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 100.100.100.41:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            rule1
            rule2
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 5
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:80 {
                address 200.200.200.101
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm rule rule1
    ltm rule rule1 {
      if { [HTTP::uri] ne "/" } {
        HTTP::redirect "http://www.google.com/"
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm rule rule2
    ltm rule rule2 {
        when HTTP_REQUEST_SEND {
      clientside {
        HTTP::header insert testHeader testvalue
     trace
    [root@B6900-R69-S40:Active:Standalone] config  ssldump -Aed -nni 0.0 port 80
    New TCP connection 1: 100.100.100.3(34895) <-> 100.100.100.41(80)
    1407680420.8779 (0.0211)  C>S
    HEAD / HTTP/1.1
    User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
    Host: 100.100.100.41
    Accept: */*
    testHeader: 1234
    New TCP connection 2: 200.200.200.40(34895) <-> 200.200.200.101(80)
    1407680421.0482 (0.1696)  C>S
    HEAD / HTTP/1.1
    Accept: */*
    testHeader: testvalue
    New TCP connection 1: 100.100.100.3(34896) <-> 100.100.100.41(80)
    1407680465.4821 (0.0006)  C>S
    HEAD /something HTTP/1.1
    Accept: */*
    testHeader: 1234
    1407680465.4822 (0.0000)  S>C
    HTTP/1.0 302 Found
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 0
