jo's avatar
jo
Oct 05, 2023
Solved
Gzip content when using HTTP::respond
I have a Virtual Server with a compression profile and an iRule that returns static text using HTTP::respond.
When using HTTP::respond the content is not compressed using gzip.
I have worked around this by placing an additional Virtual Server with a compression infront of the original Virtual Server with the iRule which then compresses the response.
Is there a way I can compress the content of a response using HTTP::respond?
Current iRule example:
	set CONTENT "Lots of text that compresses well."
	HTTP::respond \
		200 \
		content $CONTENT \
		Content-Type "text/text"
Is there a way to do something like the following (note: bogus "EXAMPLE" command placeholder):
	switch -glob [string tolower [HTTP::header Accept-Encoding]] {
		"*deflate*" -
		"*gzip*" {
			set COMPRESSEDCONTENT [EXAMPLE::gzip compress $CONTENT] ; ### Not a real command.
			HTTP::respond \
				200 \
				content $COMPRESSEDCONTENT \
				Content-Type "text/text" \
				Content-Encoding gzip
		default {
			HTTP::respond \
				200 \
				content $CONTENT \
Thanks in advance!
Jo
