Technical Forum
MTU physicla intefaces vs vlans MTU
Manu1
Hello,
About MTU, how does a Viprion behave when MTU is 9000 on physical interfaces but 1500 on vlans ?
Does he takes 9000 or 1500 ? What are the risks to have such a difference beetween MTUs ?
Thanks.
Manuel
1 REPLY 1
boneyard
MVP
MVP
after some searching i would say that traffic going through the VLAN uses 1500 and that having the interface on 9000 isn't an issue.
used this as a reference: https://serverfault.com/questions/633303/does-setting-mtu-on-logical-interfaces-affect-physical-interfaces
