15-Nov-2017
04:38
- last edited on
02-Jun-2023
10:27
by
JimmyPackets
I have tried searching for more info on getsid and getkey for ACCESS::user function.
What does these do and what are the differences? I can see only a one liner on F5 page. Can anyone help pls.
Irule example which i was going through has below entries, what do they do?
set user_key {}
append user_key $http_user "." $user_hash MD5 hash / hex encoded userpassword+IP+URL
set apm_cookie_list [ACCESS::user getsid $user_key]
set apm_cookie [ACCESS::user getkey [lindex $apm_cookie_list 0]]
HTTP::cookie insert name MRHSession value $apm_cookie
15-Nov-2017
04:45
- last edited on
05-Jun-2023
13:29
by
JimmyPackets
These are related to the outputs from the
sessiondump
command line utility. (or GUI equivalent)
https://devcentral.f5.com/wiki/iRules.ACCESS__user.ashx
set user_key {}
sets a variable 'user_key' as an empty list
appends the list with other information based on other variables (defined elsewhere)
returns the list of created external SIDs which is associated wit the specified key and stores in variable 'apm_cookie'
Returns the original SID for specified hash of SID (uses list to return the key)
inserts a cookie based on the returned session values
