09-Sep-2021 05:21
Hi all,
Hope you are doing great.
What will be the impact, if I run command "tmsh load sys config" instead tmsh load sys config verify.
Regards,
RAQS
Solved! Go to Solution.
09-Sep-2021 06:38
tmsh load sys config will verify and load the config. It will change the running config.
tmsh load sys config verify will only verify the config. It will not change the running config.
09-Sep-2021 05:47
Hi RAQS,
verify is like a dry run. It will not do anything expect of verifying syntax.
However a tmsh load sys config will also verify the config you are importing.
Depending on what you plan to do, pay attention to use the merge parameter. Otherwise you might overwrite stuff that you will desperately miss afterwards.
KR
Daniel
09-Sep-2021 05:50
Thanks Daniel for your time and reply. So "tmsh load sys config" will also not make any impact while running it in production boxes ? It will not change running config ?
Regards,
Raqs
09-Sep-2021 06:38
09-Sep-2021 06:45
Thanks Daniel. So will it have an impact ? Suppose if I run this on production box then what impact I can expect ?
