13-Nov-2022 14:57 - edited 13-Nov-2022 15:03
Hi F5 was activated with VE-Trial Registration key days ago. But due to some reason, the F5 show unlicensed status after bootup. When I use the same Reg Key to activat the same F5, it shows the below message. I do not know if this is Key issue or registration server issue. the internet is alway good. Any suggestion? Thanks
Solved! Go to Solution.
13-Nov-2022 15:07
Hi @davidy2001 ,
If this license was working with you before , you may booted up from another bootlocation other than the first used one.
-at all , try to Activate your license manually not Automatically , maybe you have issue with internet connection with F5.
Follow the steps on this Video but with manually method :
https://www.youtube.com/watch?v=osAJesgNdJc&t=103s
or
Follow this KB :
https://support.f5.com/csp/article/K7752
Regards
13-Nov-2022 15:07
Hi @davidy2001 ,
or
Follow this KB :
Regards
13-Nov-2022 19:08
@Mohamed_Ahmed_Kansoh Right, thanks
