11-Jan-2021 09:03
Hi Guys,
I need to create an iRule that will check two conditions:
1) HTTP::request contain a specific word "test"
2) The source IP is a member of the Datagroup
I would like to create an iRule using only one if statement (one line) to check both conditions above?
Thanks in advance
11-Jan-2021 19:21
Here, you can use logical AND operator to check both conditions and if both are fulfilled, set required actions.
Below is IF statement for your reference.
if { ([HTTP::host] contains "test") && ([class match [IP::client_addr] equals Allow-List]) }
Hope it helps!
11-Jan-2021 22:40
Add string tolower functions may help here.
12-Jan-2021 08:37
I can use this irule inside a HTTP_REQUEST event? The HTTP_REQUEST event allows me to check the client IP address in datagroup?
12-Jan-2021 18:11
Yes it should! I tested below iRule on my lab setup and it is working fine. You can try your iRule using above IF Statement and test.
if {([HTTP::host] contains "test") && ([class match [IP::client_addr] equals Allow-List])} {
pool TEST-Pool
log local0. "Allowed client IP is [IP::client_addr]"
log local0. "Dropped IP is [IP::client_addr]"
Hope it helps!
