Sort By
- Simon_BlakelyEmployee
From the help notes for ASM IP Address Exceptions
Note: If an IP address belongs to more than one range (using netmasks) so that there are overlapping IP address ranges, and one IP address is configured as Enabled on any setting on this screen, while another is configured as Disabled, the Enable action takes priority over the Disable action.
- Check1t_282465Nimbostratus
Thanks for the clarification.
if you feel it was the correct answer please flag it as such.
