Technical Forum
Custom Alert Banner
Identify and delete unused objects from F5 DNS (GTM)
Deepsri
Altocumulus
Altocumulus
HI,
iHealth gives us option to identify the unused obkects for BigIP LTM but no such options are available for BigIP DNS/GTM. Is there a method to identify the unused GTM objects, like the WideIP, Pool, server, Monitors etc
2 REPLIES 2
Samir
MVP
MVP
You should write script or some command combination to find the orphan object in DNS
JRahm
Community Manager
Community Manager
As @Samir mentioned, a script is warranted here. You can start with the Config Search tmsh script, which will search a given pattern and return objects matching. You can use it and iterate manually, or you can customize to meet your needs. HTH...Jason
