Technical Forum
HTTP compression not compressing all contents
mj16othman
Altostratus
Altostratus
Guys im facing an issue. Ive assigned a VIP with the default HTTP compression profile. But ive noticed the BIGIP only compressed some URLS and not all
Before compression
Compressing https://livetime.sa.zain.com/Scripts/kendo/2018.1.221/kendo.all.min.js could save 2.1MiB (71% reduction).
Compressing https://livetime.sa.zain.com/Content/kendo/2018.1.221/kendo.mobile.all.min.css could save 395.5KiB (85% reduction).
Compressing https://livetime.sa.zain.com/bundles/jqueryui?v=54OW4kCqIGAkKUGMV58PlfcIdiqcR7q3WbIkFC340hE1 could save 325.7KiB (73% reduction).
Compressing https://livetime.sa.zain.com/Content/kendo/2018.1.221/kendo.common-material.min.css could save 200.8KiB (82% reduction).
Compressing https://livetime.sa.zain.com/bundles/jquery?v=i8uCe_9DH0vtZ8EPBt3r866Ay392pkQD3h34HTx-XfQ1 could save 117.4KiB (64% reduction).
Compressing https://livetime.sa.zain.com/Content/kendo/2018.1.221/kendo.material.min.css could save 86.4KiB (86% reduction).
Compressing https://livetime.sa.zain.com/Scripts/kendo/2018.1.221/jquery.min.js could save 61.9KiB (65% reduction).
Compressing https://livetime.sa.zain.com/Scripts/kendo/2018.1.221/jszip.min.js could save 55.2KiB (69% reduction).
Compressing https://livetime.sa.zain.com/Content/css?v=iPY3eLh0P_khzhHENjzObj_Xr8gPdqbCDwl77Owme501 could save 21.9KiB (78% reduction).
Compressing https://livetime.sa.zain.com/bundles/livetime?v=FdSd5vL2s_e1TVgCPeKvGtXcmQNbgomtsXkQ2WwB6qE1 could save 21.8KiB (76% reduction).
Compressing https://livetime.sa.zain.com/Scripts/kendo/2018.1.221/kendo.aspnetmvc.min.js could save 12.0KiB (76% reduction).
Compressing https://livetime.sa.zain.com/Account/Login?ReturnUrl=%2f could save 4.2KiB (65% reduction).
Compressing https://livetime.sa.zain.com/Scripts/kendo.modernizr.custom.js could save 4.1KiB (55% reduction).
Compressing https://livetime.sa.zain.com/Content/kendo/2018.1.221/kendo.dataviz.material.min.css could save 3.8KiB (92% reduction).
Compressing https://livetime.sa.zain.com/Content/kendo/2018.1.221/kendo.dataviz.min.css could save 3.8KiB (92% reduction).
After Compression:
What can i do to compress the above remaining URLS.
1 REPLY 1
boneyard
MVP
MVP
have a look at the content list and check if the Content-Type: header matches what is included there
