Technical Forum
How to verify if mutual authentication is working or not ?
BJ_114988
How to verify if mutual authentication is working or not ? i can see that there is openssl command to veriify it.
Can someone please explain more about it and give commands ?
1 REPLY 1
Samir_Jha_52506
Noctilucent
Noctilucent
@BJ, If i understand correctly you wanted to test client authentication right? If Yes, below syntax can help you..
    openssl s_client -connect : -key  -cert
Cheers...
