alven_kim's avatar
alven_kim
Apr 05, 2021
how to use h2c recv/recv-disable pool members
Hello, everyone.
I want to check the pool member status by utilizing the monitor for HTTP/2(h2c) which is recv/recv-disable.
EAV only checks State Up/Down.
The Monitor-Up (Enabled/Disabled) option is not available on EAV.
I tried to implement it with i-rule, but I'm having a hard time because I'm not familiar with Tcl.
Is there any way to use recv/recv-disable monitor for h2c?
Any way is fine, so please give me a guide me.
Thank you.
    • alven_kim's avatar
      alven_kim
      Hello, Lidev
      I read the document you told me.
      However, it does not seem necessary because it is a story about HTTP/2(h2). I need a monitor (enabled/disabled) for HTTP/2(h2c).
      The purpose is to utilize SSL Termination as HTTP/2.
      Architecture) AS-IS
      Client -------------------- BIG-IP -------------------- Server(App or WAS)
      .................HTTP/1.1.........................HTTP/1.1
      Architecture) TO-BE
      ...............HTTP/2(h2)..................HTTP2(h2c)​
      This is because F5 is used for rolling-deployment.
      Therefore, you should use h2c to make the monitor (enabled/disabled) distinguished.​
      Regards
