Sharath413's avatar
Sharath413
Dec 11, 2020
Solved
How to passively monitor Dataguard without masking data?
I have a security policy in blocking with "Data guard:info leakagae detected" set to alarm and learn. I disabled everything under security--application security--data guard.
How can I enable data guard in this scneario such that Big-IP will not mask or block the data but just show the logs and learning suggestions?
