Dec 18, 2016
Getting maximum TPS and TPS usage through iControl rest
Hi!
I'm trying to extract the maximum licensed TPS via iControl rest but struggling to find the value.
It's possible with tmsh:
tmsh show sys license detail
Active Modules
Compression, Unlimited (XXXXXX-XXXXXX)
LTM, Base, C2400 (XXXXXX-XXXXXX)
IPV6 Gateway
Rate Shaping
Ram Cache
50 MBPS COMPRESSION
SSL, 500 TPS Per Core
Cluster Multi-Processing
APM, Limited, Viprion
App Tunnel
Anti-Virus Checks
Base Endpoint Security Checks
Firewall Checks
Machine Certificate Checks
Network Access
Protected Workspace
Remote Desktop
Secure Virtual Keyboard
APM, Web Application
SSL, C2200/C2400
AAM, Core
VCMP Enabled, C2400 (XXXXXXX-XXXXXXX)
But issuing the "same" command via iControl rest does not yield the same information:
curl -sku user:password https://172.18.155.153/mgmt/tm/sys/license/stats?options=detail | json-format
"kind": "tm:sys:license:licensestats",
"selfLink": "https://localhost/mgmt/tm/sys/license?expandSubcollections\u003dtrue\u0026options\u003ddetail\u0026ver\u003d11.5.4",
"entries": {
"https://localhost/mgmt/tm/sys/license/0": {
"nestedStats": {
"entries": {
"applianceSerialNumber": {
"description": "bld000000s"
"chassisId": {
"description": "chs000000s"
"licensedOnDate": {
"description": "2012/10/03"
"licensedVersion": {
"description": "10.2.3"
"optionalModules": {
"description": "{ \"Acceleration Manager, C2400\" \"ADC, Security Bundle, C2400\" \"Advanced Protocols\" \"AFM, C2400\" \"APM, Base, C2400\" \"APM, Max Access Sessions, C2400\" \"APM, Max CCU, C2400\" \"App Mode (TMSH Only, No Root/Bash)\" \"ASM, Bundle, VIPRION\" \"ASM, PSM to ASM Upgrade\" \"ASM, Unlimited, VIPRION\" \"Best Bundle, C2200 / C2400 Platforms\" \"Better Bundle, C2200 / C2400 Platforms\" \"Better to Best Bundle, C2200 / C2400 Platforms\" \"CGN, Viprion\" \"Client Authentication\" \"DNS and GTM (1K QPS), VIPRION\" \"DNS and GTM (Unlimited), VIPRION\" \"DNS Services, VPR\" \"External Interface and Network HSM\" \"FIX Low Latency\" \"GTM\" \"IPI Subscription, 1Yr, C2400\" \"IPI Subscription, 3Yr, C2400\" \"MSM, Unlimited Mailboxes\" \"PEM URL Filtering, Subscription, 1Yr, C2400\" \"PEM URL Filtering, Subscription, 3Yr, C2400\" \"PEM, C2400\" \"PEM, Quota Management, C2X00\" \"Performance Extreme, VPR\" \"PSM, Base\" \"Routing Bundle\" \"SDN Services\" \"SSL, Forward Proxy\" \"SSL, Unlimited, C2400/C4400/C4480\" \"SWG 1Yr, C2200/C2400, 60K URL Sessions\" \"SWG 3Yr, C2200/C2400, 60K URL Sessions\" \"SWG Subscription, 1Yr, C2200/C2400\" \"SWG Subscription, 3Yr, C2200/C2400\" \"URL Filtering Subscription, 1Yr, C2200/C2400\" \"URL Filtering Subscription, 3Yr, C2200/C2400\" \"URLF 1Yr, C2200/C2400, 60K URL Sessions\" \"URLF 3Yr, C2200/C2400, 60K URL Sessions\" \"VIPRION, Multicast Routing\" \"WBA, Bundle, C2400\" }"
"platformId": {
"description": "A109"
"registrationKey": {
"description": "XXXXX-XXXXX-XXXXX-XXXXX-XXXXXX"
"serviceCheckDate": {
"description": "2016/08/16"
Maybe there's a different resource to use?
And... while we're on the subject. What happened to /mgmt/tm/sys/performance?
I know Rest is not meant to be used for statistics, but it's what my client uses so that's my only option at the moment (except for tmsh, which is a bit more demanding from the unit in terms of performance).
/Patrik
