24-Jan-2020 09:25
Hello everyone 🙂
I am trying to integrate a F5 LTM VE (15.1.x) on my ESXI.
Just after the deploiment, the console is crawling under broadcast message about tmm, here an example :
Broadcast message from systemd-journald@hostname (Wed 2019-04-24 12:33:07 CEST): logger[13322]: Re-starting tmm3
It seems to be related to the virtual network device from Vsphere.
I also tried to list my current interfaces with tmsh list net interface, but the interface have no MAC address, thats weird right ?
Does anyone had this situation before ?
Best Regards
Solved! Go to Solution.
31-Jan-2020 06:29
Ok, i have found a solution on this.
It seems that my esxi is not delivering amount of memory I asked for.
I reduced the memory per VM and now everything seems to work correctly.
Thanks !
Best Regards,
25-Jan-2020 10:19
Hi Fouad,
did you pick the OVA and loaded it into your ESXi ? and checked compatibilty with your ESXi version ?
and when you start the VE from the OVA, be sure to not upgrade the ovftools inside your VE.
HTH
28-Jan-2020 02:13
Hi Philipe,
Yes the ESXI is compatible with my version of F5 LTM, and I did not upgraded the ovftools in my VM.
The broadcast are happening right after the boot.
If I try to get the mac adress from my interface with this command :
The broadcast message start for sure every time ...
Best Regards,
28-Jan-2020 08:14
Hi again,
I checked the file /var/log/tmm and I have this error message all over the file
<13> Jan 28 08:11:10 node-02 notice map_tmm_memory: set_mempolicy 0 node 0x0 failed 22 (Invalid argument)
Hmm seems to be a memory problem ....
31-Jan-2020 06:29
Thanks !
Best Regards,
