seamlessfirework's avatar
seamlessfirework
Jul 11, 2023
Solved
Declarative Onboarding / Configuration not or partially deployed and configuration deletion
Hey guys
I recently experimented with DO and I am kind of confused. I installed the DO app as described in the guide and tried a simple DO declaration. The only configuration that changed after the Postman POST request were DB vars for UI advisory (enabled, color green, hostname /Common/hostname). Network interfaces, hostname, NTP servers etc. were not changed.
I changed the advisory stuff from color green to blue and the hostname to /Common/bigip. It worked out in the first place but some time later it switched back to the old configuration without hitting a key.
This is a weird behavior. I searched the Internet to wipe the DO configuration but found nothing. Can you give me some hints about what I am doing wrong and/or deleting the DO configuration?
This is my JSON declarationfrom the F5 DO example, slightly eddited.
    "schemaVersion": "1.0.0",
    "class": "Device",
    "async": true,
    "webhook": "https://example.com/myHook",
    "label": "my BIG-IP declaration for declarative onboarding",
    "Common": {
        "class": "Tenant",
        "mySystem": {
            "class": "System",
            "hostname": "octopus.ocean.com",
            "cliInactivityTimeout": 1200,
            "consoleInactivityTimeout": 1200,
            "autoPhonehome": false
        "myDns": {
            "class": "DNS",
            "nameServers": [
                "192.168.124.1"
            "search": [
                "ocean.com"
        "myNtp": {
            "class": "NTP",
            "servers": [
                "0.pool.ntp.org",
                "1.pool.ntp.org",
                "2.pool.ntp.org"
            "timezone": "UTC+2"
        "guestUser": {
            "class": "User",
            "userType": "regular",
            "password": "guestNewPass1",
            "partitionAccess": {
                "Common": {
                    "role": "guest"
        "anotherUser": {
            "class": "User",
            "password": "myPass1word",
            "shell": "none",
                "all-partitions": {
                    "role": "guest"
        "myProvisioning": {
            "class": "Provision",
            "ltm": "nominal",
            "gtm": "minimum"
        "external": {
            "class": "VLAN",
            "tag": 2901,
            "mtu": 1500,
            "interfaces": [
                    "name": "1.1",
                    "tagged": true
            "cmpHash": "dst-ip"
        "external-self": {
            "class": "SelfIp",
            "address": "192.168.180.4/24",
            "vlan": "external",
            "allowService": "default",
            "trafficGroup": "traffic-group-local-only"
        "default": {
            "class": "Route",
            "gw": "192.168.180.1",
            "network": "default",
            "mtu": 1500
        "dbvars": {
            "class": "DbVariables",
            "ui.advisory.enabled": true,
            "ui.advisory.color": "green",
            "ui.advisory.text": "/Common/hostname"
