Connection limit for a URI path.
Hi
I just got the question to put a connection limit for a single URI path of a virtual server.
The virtual server is used for multiple applications. so like, www.example.com/app1 or /app2.
So If i set the connection limit for the example.com virtual server, the connection limit is set for both app1 and app2. The virtual server has a rewrite profile for this.
Is it possible to set a connection limit for a single application?
The only way I can see it work is an irule, but i'm pretty new to irules, I haven't found anything on the internet about this.
Any help is appreciated. Thanks in advance!
You are looking after limiting L7 requests and not L4 connections which are not aware of the /app1 /app2... paths.
This iRule is a good starting point :
# This iRule limits the number of HTTP Requests from a specified client IP address to 100 HTTP Requests for 5 minutes # A Data Group IP_Throttle_List will contain the IP addresses that require throttling when HTTP_REQUEST { # Check if the IP address is within the defined list of addresses to throttle if { [class match [IP::client_addr] equals IP_Throttle_List ] } { # Check if there is an entry for the client_addr in the table if { [ table lookup -notouch [IP::client_addr] ] != "" } { # If the value is less than 100 increment it by one log local0. "Client Throttle: Value present for [IP::client_addr]" if { [ table lookup -notouch [client_addr] ] < 100 } { log local0. "Client Throttle: Number of requests from client = [ table lookup -notouch [client_addr] ]" table incr -notouch [IP::client_addr] 1 } else { log local0. "Client Throttle: Client has exceeded the number of allowed requests of [ table lookup -notouch [client_addr] ]" # This else statement is invoked when the table key value for the client IP address is more than 100. That is, the client has reached the 100 request limit HTTP::respond 200 content { <html> <head> <title>Information Page</title> </head> <body> We are sorry, but the site has received too many requests. Please try again later. </body> </html> } } } else { # If there is no entry for the client_addr create a new table to track number of HTTP_REQUEST. Lifetime is set to 5 minutes log local0. "Client Throttle: Table created for [IP::client_addr]" table set [IP::client_addr] 1 300 } } else { return } }You can remove the class match part if not needed. And you can add the check of the exact path requested by the client using :
if { [HTTP::uri] starts_with "/app1" } { ... }Let me know if that helps
