19-Nov-2021 03:44
I can’t find the reference to connect 2 B4450 through a 40gb port (For failover), which cable is supported, it can be Transceiver to Transceiver (8-fiber parallel transceivers 40G / 100G, SR4, PSM). The idea is to connect one card to the other, between 2 chassis, to build the failover between them. Thanks a lot.
22-Nov-2021 02:00
Hi Daniel,
I think you have to use transceivers and fibers, because afaik there are no 40G DACs.
See here: https://techdocs.f5.com/en-us/hw-platforms/f5-plat-accessories/title-transceivers.html#fiber-sfpplus-specs
If your chassis are relatively close to one another I'd go for F5-UPG-QSFP+BD. It supports up to 100 meters using OM3 fibers, and the connector is a standard LC duplex. If you need more than that distance, OM4 fibers can get you up to 150 meters.
If you already have 8-fiber parallel fibers with MPO/MPT connectors you can use F5-UPG-QSFP+SR4.
More than that (up to 10 km), you'll have to switch to single-mode fibers and use F5-UPG-QSFP+LR4 or F5-UPG-QSFP+PSM4.
/Mike
23-Nov-2021 04:12
23-Nov-2021 10:41
Hi Daniel,
You'll need a MPT/MPO-terminated OS2 8-fiber cable. Which, according to a fast search, is incredibly hard to find. I'm not sure if a 12-fiber cable would work.
I wonder why would one buy long range transceivers to connect things within a data center, but I guess now it's too late to change that 😞
