19-May-2021 03:53
Hi all
I have an odd problem.
There is a virtual machine (BigIP VE) with version 13.1.3.x with enough ressources (RAM, CPU, disk) which crashes when I try to upload an ISO for upgrading using SCP/SSH (not the WebGUI!).
When I start the upload it takes a moment (it ranges from 10 to 35% progress) the VE crashes either completly or starts to act strangely (not login possible anymore, but the traffic is still running).
I have to power off the VM and then power it on again to actually remedy the issue.
We will have an extensive testing with the ESX team and checking the VE itself, but preliminary checks don't show any issues with storage (ESX wise or internally VE, there is enough space) or ressources (like CPU, RAM, etc.).
There is a second VM with the same statistics and same version, just another location and another ESX farm, but that one doesn't have an issue.
Beside the fact we certainly need to check more in depth with ESX, anyone an idea what I could check on the F5 side what might cause this?
Thanks a lot
19-May-2021 07:33
Hi scheuri,
That's an interesting problem indeed!
Here are a few tips that are hopefully helpful in getting to the bottom of it;
19-May-2021 07:41
Hello AlexBCT
Thanks a lot for your reply.
