Technical Forum
BIG iQ discovery issues with error Unauthorized 401
ashu_aggarwal1
Altostratus
Altostratus
I am experiencing discover issue while trying to add the F5 LTM guest to BIG IQ, Its throwing error as "check credentials: Unauthorized(401)" even though the credentials are correct.The guests are running code 15.1.5.1.. Big IQ is running 8.1.0.2
I have tried clearing reset java storage as well as restjavad process. Any suggestion would be greatly appreciated.
7 REPLIES 7
Paulius
MVP
MVP
Have you confirmed that the request from the BIG-IQ is making it to the BIG-IP in question? Are you 100% certain that they are the correct credentials for the admin user of the BIG-IP? You should be able to perform a tcpdump on the BIG-IP on the interface that the BIG-IQ is connecting to so you can validate the request is making it to the BIG-IP. You should also be able to validate the user attempted to log into the BIG-IP by checking the audit logs.
Mike757
MVP
MVP
Hi ashu,
You have to use "admin" - not "root" - credentials - either the admin user itself or a user with similar privileges.
/Mike
Thanks all for the reply, I have tried to use admin/root as well as my Tacacs credentials and all of them throwing this error.  I dont see this issue with code 15.1.6.1.
The connectivity from BIG IQ to the VCMP guest is good as i can telnet over port 443 as well as 22.
So, no issues with BIG-IP 15.1.6.1, but 15.1.5.1 doesn't work?
If you still have any BIG-IP in the error conditions, give this article a go: https://support.f5.com/csp/article/K40573362
/Mike
Yes thats correct, No issues with 15.1.6.1.
I have already tried to clear rest java storage and restated the restjavad process as well, i know the upgrade to 15.1.6.1 will fix the issue however was looking for some workaround solution.
This is crazy... can you try a reboot of the BIG-IP, just to take some weird cache issue out of the way?
/Mike
Leslie_Hubertus
Community Manager
Community Manager
Hi @ashu_aggarwal1 - were you able to resolve your issue with the help from @Mike757 and @Paulius, or are you still having problems?
