Technical Forum
Big-IP LTM - load balancing incoming request to 2 different 'paths' on Member Pool
chris_wood
A strange request has come in :).  I donlt think it's possible but thought I'd reach out just encase some has an answer.
We have a VS setup that load balances to 2 different servers.
In this example we need the incoming request to load balance to a different path on each server, e.g.
incoming request > VS
VS re-writes/redirects the URL to:
Load balance to server 1 path   (https://example1/folder/folder/server1
Load balance to server 2 path  (https://example1/folder/folder/server2
Many thanks in advance!
Chris
13 REPLIES 13
Hi @chris_wood ,
What I understood , you need to redirect any incoming request ( http://example1 )
to  (https://example1/folder/folder/server1) and (https://example1/folder/folder/server2)
at the same time and forward it to two different servers at the same time as well.
Interesting , could you please clarify more , to figure out your request
_______________________
Regards
Mohamed Kansoh
Hi Mohamed,
Thanks for your reply.
Basically, we want to load balance (round robin for e.g) to 2 servers in the member pool - but before passing it on to the servers, we need the Virtual Server to re-write the URL path to a different specific folder on each server:
The reading I've done so far suggests when we use the HTTP::redirect iRule, the F5 replies directly to the client and doesn't load balance (even then sending to 2 different locations is a big ask).
In the mean time, we are looking into completing this task using re-directs on the individual servers, as I think that makes more sense.
Thanks @chris_wood ,
> So you have a pool has two ( servers/pool members )
> and Roundrobin Load balancing technique.
> After selecting server1 for example , modify request from ( http://example ) to  (https://server1/folder/folder/server1)  and same for Server2 but with server2 path.
That's all ?
Let me try to test it in my lab and reply back to you
Regards
Mohamed Kansoh
Yes - that's everything!
Might be as easy as this:
Not sure if LB::server name returns the correct information
when LB_SELECTED {
#  log local0. "server [LB::server name]"
  set path "/folder/folder/[LB::server name]"
  HTTP::host "[LB::server name].local.domain"
  HTTP::path $path
CA_Valli
MVP
MVP
It's not optimal, but technically it should be possible.
If you want to have it work dinamically, I'd suggest to configure the objects with a specific naming convention , for example referencing the path.
I haven't tested this code, but you could try something like this:
when LB_SELECTED {
when SERVER_CONNECTED {
  HTTP::path "$path"
Ok @chris_wood ,
This Irule Code should meet your need :
when LB_SELECTED {
if { [IP::addr [LB::server addr] equals x.x.x.x] } {
log local0. " Server 1 selected , Change path to ( http://example/folder/folder/server1 ) "
HTTP::uri "http://[HTTP::host]/folder/folder/server1"
} elseif { [IP::addr [LB::server addr] equals x.x.x.x] } {
log local0. " Server 2 selected , Change path to ( http://example/folder/folder/server2 ) "
HTTP::uri "http://[HTTP::host]/folder/folder/server2"
#Replace "x.x.x.x" Ips by your servers/poolmembers IPs.
#First "x.x.x.x" server1 and second "x.x.x.x" server2
>> I have tested it and it works as expected , after capturing the traffic in both sides , I observerd the chaning in URI paths according to selected pool member inside the pool.
<< Why I used this method >> ?
Because you need to use round Robin loadbalance technique and modify the request to servers at the same time.
try it and let me know.
Goodluck 🙂
Regards
Mohamed Kansoh
This works, I was wondering if there was a way to make it dynamic so it was scalable ..
I've looked into [LB::server] instruction and tested it, but it only returns server IP and pool name.
@chris_wood if you have control on the server environment and it's possible to edit the URLs, you might want to set it up this way:
- assign any IP address you want
- if possible, try configuring server hostname to match the last octect ex. apache30 for IP 10.10.10.30 or apache12 for 10.10.10.12
- if possible, configure server URL to match the hostname, ex. /path/to/apache15
This way, iRule might support service scalability as server farm grows,
when LB_SELECTED {
  set selected [getfield [LB::server addr] "." 4]
  set server "apache$selected"
#  log local0. "server $server"
  set path "/path/to/$server" ; set host "$server.local.domain"
  HTTP::host $host
  HTTP::path $path
This will rewrite  http(s)://<virtual server url>   to    http(s)://apacheXX.local.domain/path/to/apacheXX for any given XX , without redirects (client transparent)
Thank you! I will test this afternoon and let you know!
Hi!
I tried your script - and looks good in the F5 logs - however the server logs aren't showing showing any connections.
Tried on both http/https - with the http & http-transparent profile.  I'm thinking along the lines of SSL/TLS getting in the way - might need to add
Removing the http profile and only using 1 server in the pool worked as expected.
Hi @chris_wood ,
While assinging my iRule script in your virtual server, did you assign the correct pool in Virtual server resources ?
you sould assign a pool has 2 pool members ( and only replace first "x.x.x.x" by first pool member IP and do the same with the second pool member ip )
Please Take this Packet capture to see the server and client side connections , and see the effect from F5 Bigip
tcpdump -nnni 0.0:nnnp -vvv -w /var/tmp/path_test.pcap host x.x.x.x
#put Client_ip address instead of "x.x.x.x"
 I will be waiting your response
Regards
Mohamed Kansoh
Thanks very much for your help!  Really appreciated.
I added the web server certificate as a client/server SSL profile, this helped the F5 load balance as expected - however it still wasn't re-writing the URI (this was most likely a config issue on my end)
During out T/Shooting - we decided to go down the web server redirect route as this easy to implement.
HI @chris_wood ,
Take Packet capture in both sides Client/server sides you will be able to see that Bigip rewrites your URI ,
Look at this from my enviroment after testing the iRule that I shred it with you :
where :
10.1.10.199  >>> Client address
10.1.10.100 >>> Virtual server
10.1.20.240 >>> F5 Bigip selfip address in server side/ ( intrtnal vlan)
10.1.20.11 >>> Server 1
Do you observe the rewriting of the uri , according to choose server 1 in loadbalancing.
Also this when Loadbalancing algorithm chose server 2 :
10.1.20.12 >>> server 2
So that take a packet capture that I sent in my last reply  and the the change through F5 bigip first.
if the rewriting goes well , send it to the server owner and tell him that he needs some modification from his side as bigip did it's job.
Let me know if you need somthing
Regards
Mohamed Kansoh
