mf5's avatar
mf5
Apr 27, 2020
ASM brute force configuration for Exchange EWS
Hello,
We want to configure brute force protection on the exchange ews login page https://abc.com/ews/exchange.asmx.
When we use in authentication-type HTML and parameters (username&password) in login url, username is not detected and when we test protection it's not working. And it is the same with when we use authentication-type NTLM in the login url, username is not detected and protection is not working.
Need help to configure it.
Thanks.
  • how do you determine it is not working?
    when you normally go to the page do you get a logon page or just NTLM or HTTP Basic single sign on?
    you do SSL offloading if that is required?
    which TMOS version? not 11.6 by chance? https://support.f5.com/csp/article/K05113177
