Technical Forum
Custom Alert Banner
APM VIP with exchange servers and NTLM authentication
Kaloyan
Cirrus
Cirrus
I used the exchange 2016 iApp ( latest version) to setup one VIP with all services behind it.
The problem is that /mapi* should be with NTLM authentication, but rest of it like /owa is using basic authentication.
Right now the policy is setup with logon page -> LDAP Authentication -> SSO credential mapping - Allow
Pretty standard. The question is, could I insert upfront logon page NTLM check based on URI ?
Something like this :
and iRule , if needed :
  if { [HTTP::uri] starts_with "/mapi" } {
    ECA::enable
    ECA::select select_ntlm:/Common/ntlm-auth-exchange-2016
    ECA::disable
2 REPLIES 2
youssef1
Cumulonimbus
Cumulonimbus
Hello Kaloyan,
Did you use an Exchange profile?
Because you can easly set frontend Authentification and SSO by URL/Service:
Regards
Hi youssef,
yes, I have exchange profile.
Can I borrow one of the predefined Service Settings and add /mapi* instead of /ews* for example ?
And probably will need to add SSO Configuration with Kerberos for NTLM ?
Should I change the policy as well with some NTLM checks ?
Do I need this ECA enabled on the VIP ?
So many questions 🙂
