svs's avatar
svs
Jan 14, 2019
APM SSLVPN with layered virtual
Hi guys,
I'm trying a new (for me), but oftenly recommended by F5 SEs, setup with layered virtuals. In my testing environment, I have only one single IP address. This is used for a standard virtual server, which will be used as some kind of a jump VS (let's call it 'VS_jump'). I've assigned an LTM policy to this VS, which forwards the traffic to different virtuals, based on the requested host header.
Basically this is working finde. But I'm struggling arround with APM and SSLVPN (Network Access). The requests hit the correct VS ('VS_apm-sslvpn') with APM profile assigned and the user is able to authenticate. But after opening the PPP tunnel, it's ending in a timeout for the client. The APM log tells me, that the tunnel was directly closed:
PPP tunnel 0x56009ef6dd00 (ID: 703c0a5b) started.
PPP tunnel 0x56009ef6dd00 (ID: 703c0a5b) closed.
This issue only occurs, if the APM profile is bound to the forwarded virtual, 'VS_apm-sslvpn'. For testing purposes I've assigned the APM and connectivity profile to 'VS_jump' and the connection came up directly, without any issue. The message
only appears, when the connection is manually disabled.
So my question is: Are there any known limitations to SSLVPN, when used in conjunction with layered virtuals? I'm not sure about settings like HTTP-XFF or SNAT - where shall they be set? On 'VS_jump' or 'VS_apm-sslvpn'.
Unfortunately I wasn't able to find anything related to SSLVPN and layered virtuals.
Any ideas?
Thanks in advance.
Cheers,
Sven
  • The best solution is to create a layered policy based on Client Hello SNI value instead of HTTP Host header..
    https://devcentral.f5.com/articles/sni-routing-with-big-ip-31348?tag=SNI
    This solution allow to route based on SNI (default value from browser is the same value as HTTP host). this doesn't require to add SSL / HTTP profiles on front virtual server.
    Another improvement is to enable DTLS virtual server (udp/4433) to optimize VPN performance. This virtual server doesn't require to be layered as it is only for VPN.
    • adri8n's avatar
      adri8n
      I'm using SNI routing configured almost exactly like the article, matching at client ssl hello and forwarding to an APM SSLVPN enabled VS.
      Same symptoms as OP.
      Is there some other magic to making this work, or is it not supported?
      Sven, did you ever happen to get this to work?
      • svs's avatar
        svs
        yes I got this working. Can't remember, why I didn't respond to Stanislas answer.
        My LTM Policy looks like the following:
        ltm policy SNI-Routing {
            controls { forwarding }
            requires { client-ssl }
            rules {
                Default {
                    actions {
                        0 {
                            log
                            ssl-client-hello
                            write
                            facility local0
                            message "Nothing mathed on hostname"
                            priority info
                    ordinal 1
                vpn.example.com {
                    actions {
                        0 {
                            forward
                            ssl-client-hello
                            select
                            virtual /Common/vpn.example.me_ap_vs
                    conditions {
                        0 {
                            ssl-extension
                            ssl-client-hello
                            server-name
                            values { vpn.example.com }
            status published
            strategy first-match
        VS
        ltm virtual vpn.example.me_ap_vs {
            destination 1.1.1.10:443
            ip-protocol tcp
            mask 255.255.255.255
            profiles {
                http { }
                ppp { }
                rba { }
                tcp { }
                vpn.example.me_ap { }
                vpn.example.me_ap_cp {
                    context clientside
                vpn.example.com {
                    context clientside
                websso { }
            source 0.0.0.0/0
            translate-address enabled
            translate-port enabled
        VS DTLS
        ltm virtual vpn.example.me_ap_vs_dtls {
            destination <External Self IP>:4433
            ip-protocol udp
            profiles {
                ppp { }
                udp { }
                    context clientside
                vpn.example.com {
                    context clientside
            source 0.0.0.0/0
        The DTLS VS is not going through the LTM SNI Routing policy. Instead it is, in my case, bound directly to the external Self IP, with only SSL client profile and connectivity assigned.
        APM Profile
        apm profile access vpn.example.me_ap {
            accept-languages { en }
            access-policy vpn.example.me_ap
            app-service none
            customization-group vpn.example.me_ap_logout
            default-language en
            eps-group vpn.example.me_ap_eps
            errormap-group vpn.example.me_ap_errormap
            framework-installation-group vpn.example.me_ap_framework_installation
            general-ui-group vpn.example.me_ap_general_ui
            generation 1
            generation-action noop
            log-settings {
                default-log-setting
            modified-since-last-policy-sync true
            type all
            user-identity-method http
        Connectivity Profile:
        apm profile connectivity vpn.example.me_ap_cp {
            adaptive-compression enabled
            app-service none
            client-policy {
                    ios-ec {
                        save-password true
                    ios-ep {
                        save-password true
            compress-buffer-size 4096
            compress-cpu-saver true
            compress-cpu-saver-high 90
            compress-cpu-saver-low 75
            compress-gzip-level 6
            compress-gzip-memlevel 8192
            compress-gzip-window-size 16384
            compress-ingress false
            compression enabled
            compression-codecs { deflate lzo bzip2 }
            customization-group vpn.example.me_ap_cp_secure_access_client_customization
            defaults-from connectivity
            deflate-compression-level 1
            description none
            fec-name none
            location-specific false
            tunnel-name vpn.example.me_ap_cp
        Hopefully this help.
        Cheers
        Sven
