Technical Forum
APM Reset Fallback
Satoshino
Cirrus
Cirrus
Hi guys,
I have this setup:
I would like to know how to prevent users, when they end up in fallback, receive the error message indicating the session.
Is there a way to send a reset without messages?
Best regards
3 REPLIES 3
Daniel_Wolf
Nacreous
Nacreous
Hi Satoshino,
you can modify what your users will see see in ending pages. There is a manual chapter for "BIG-IP Access Policy Manager: Customization Access Profile and Per-Request Policy - Logout/Ending Deny - Modern and Standard" (BIG-IP 15 and 16) or "Localizing ending pages" (BIG-IP 14).
Links for
Is this what you were looking for?
KR
Daniel
Satoshino
Cirrus
Cirrus
Hi Daniel,
Thanks you for manual, but this was not what I need.
I need a way to drop session without show any page.
I tried to use irule event with "drop" or "ACCESS::session remove" like this:
when ACCESS_POLICY_AGENT_EVENT {
    log local0. "log"
    drop
#  ACCESS::session remove
But the result is the same.
Best regards
can you share why you want this?
because in general you just want to show something if it fails. total reset / drop will just cause someone to be left behind wondering what happened, pressing F5 and starting over.
perhaps looking at ACCESS::disable can get you somewhere, that should stop APM from acting. but still perhaps share your overall question / case so someone can think on that.
