Transparent Kerberos Authentication and APM fallback authentication
Problem this snippet solves:
This iRule can be used when it is required to offer both Kerberos authentication (transparent, non-APM) and for example SAML or another APM authentication method in a mixed environment for devices that are domain joined and devices that are not domain joined. This iRule uses javascript and HTML5 Web Workers to determine if the browser can successfully authenticate by using Kerberos or will need to fallback to another authentication method.
I've been testing this iRule with Internet Explorer, Edge, Firefox and Chrome. All these browsers seem to be working fine. Only Chrome seems to do things a bit differently and is showing a login prompt for a split second, but it's working.
How to use this snippet:
Create a Virtual Server that delivers a webserver that uses Kerberos Authentication. Create APM Access Policy that will perform the fallback authentication. Add this iRule to the Virtual Server that holds the APM access policy to perform the fallback authentication.
Tested this on version:
13.0
Location of iRule
https://github.com/nvansluis/f5.transparent_kerberos_auth_or_apm_authentication
2 Comments
- Walter_Kacynski
It seems like this code got lost in the migrations 😞
Walter_Kacynski sorry I didn't see your comment earlier. I've added the link to the github repository.
