Add FQDN Node to a Pool with autopopulate enable
Cmora2488
Hey Team,
I encountered some issues on the cluster of the LB if I add FQDN Nodes to the pool.
As per F5 support we have to add the nodes to the pool with the Auto Populate Enable since that can cause problems.
I am trying to find a way when we add the nodes with that feature on however i am not able to find it
This is my code
   def add_node_to_pool(self, node_name, pool_name, port_number):
        # method to add node to the pool created
        my_pool_add = self.mgmt.tm.ltm.pools.pool.load(name=pool_name)
        my_pool_add.members_s.members.create(partition='Common', name=node_name + ':' + port_number)
        my_pool_add.update()
        print('Node ' + node_name + ' added to pool ' + pool_name)
1 REPLY 1
Cmora2488
I was able to figure it out
This is the code to add nodes with autopopulate for FQDN
 self.mgmt.tm.ltm.nodes.node.create(partition='Common',name=deviceinfo[0], fqdn={"name":deviceinfo[0],"autopopulate":"enabled"}, description='Added With Script')
        my_pool_add.members_s.members.create(partition='Common', name=node_name + ':' + port_number,fqdn={"autopopulate":"enabled"})
