sbrock's avatar
sbrock
9 months ago
Win 10 and Server 2016 clients will not connect. Stuck on Initializing
I have 2 Big Edge clients (one Win 10, the other Server 2016) that have recently stopped connecting.
Clicking "Connect", I see the messages, Downloading Server Settings, Connecting to Server, Retrieving Information, Initializing, but the client does not connect.  In the Connection Details tab, the status is Connected, but there is no IP address.
This happens on both clients.  Both clients are running v 7251.2025.122.1852.  On Server 2016, I uninstalled the client and installed an older client - v7110.2015.423.1748.  This version also does not connect.  I then let the Big Edge client update, but it still will not connect.
I tested on a Win 10 laptop and it is able to connect, so the problem is not my credentials.
Server 2016 stopped connecting about a month ago.  I also tested with the Chrome browser.  After entering my credentials, the browser client will not connect.
I have attached a screenshot of some errors in the logs.
Any ideas or suggestions?
  • sbrock's avatar
    sbrock
    I was able to get the client to connect on my Win 10 laptop by following the steps in the article above but I deleted all the WAN Miniport adapters in Device Manager.  I had an older client installer, so after letting it update to the latest client, I was able to connect to the VPN.
    However, this process did not work on the Server 2016 machine - which is the one I ready need to connect.  It has a database installed that I can't move at the moment.  After following the same steps above as the Win 10 machine, the Big Edge client now stays on "Initializing".
  • sbrock's avatar
    sbrock
    A little more information:
    We are a hosted Powerschool customer.  The 2016 server runs a SQL database and uses the Big IP Edge Client to connect to the VPN Powerschool set up so we can connect to the Oracle database.  Prior to June 28, 2025, the Big IP Edge client would connect to Powerschool's VPN and we could access the Oracle database directly.   On June 28, Powerschool performed maintenance on their servers:
    Reason for Maintenance:
    PowerSchool will be conducting maintenance on the PowerSchool SIS, including F5 SSL VPN maintenance. During the F5 software upgrades, customers may be required to reestablish their VPN sessions. The application will be accessible most of the time during the maintenance window. However, customers may experience intermittent connectivity.
    After the June 28 maintenance, the Edge client will no longer connect.  We are not the only Powerschool customers affected.  After opening a support ticket with Powerschool and having the issue escalated, Powerschool's recommendation is to upgrade the server to 2022.  This is not a simple/quick task since our Server 2016 is running an SQL data and the vendor would need to reinstall their application on an upgraded server.
    Powerschool support response:
    Unfortunately, at this time, our recommended resolution is to upgrade to Windows Server 2022.  I do know that our Hosting team is working with F5 to see if there may be another resolution.  I will keep you posted on what they hear from the vendor.  Below is a link to an article referencing the June 28, 2025, SSL VPN Reconnection required maintenance.  In the comments, there was a customer who rolled the client back and was able to get the issue resolved, but I believe you already tried that.
    • sbrock's avatar
      sbrock
      I do not know the exact update.  I would lean to say they did not force TLS_1.3.  I can connect with Windows 10.
    • sbrock's avatar
      sbrock
      Latest from Powerschool:
      As part of our ongoing commitment to maintaining a strong security posture and staying aligned with supported product lifecycles, we recently completed an upgrade to our F5 infrastructure. (per the notification sent on 6/28/2025). Following this upgrade, we were made aware of connection issues specifically impacting legacy Windows Server operating systems when using the SSL VPN (Edge Client). Please note that F5 does not support SSL VPN connections from any Windows Server operating system, as this offering is intended for use on client machines only. To ensure seamless connectivity, we recommend using a supported client device running Windows 10 or Windows 11, both of which are fully supported by F5 for SSL VPN access.
      Powerschool gave me a link to a compatiblity matrix.  The below is listed in the link.  Does this mean the Big IP Edge client is supported on Windows Server 2016?
      Remote Desktop Gateway Compatibility Matrix
      The following server products were qualified for compatibility with F5 BIG-IP APM Secure Remote Desktop Gateway:
      • Microsoft Windows Server 2016
      • Microsoft Windows Server 2012 R2
      • Microsoft Windows Server 2008 R2 SP1*
      • Microsoft Windows 10
      • Microsoft Windows Server 2019
      • Microsoft Windows Server 2022
