chethan_181144's avatar
chethan_181144
Jul 10, 2017
which IP does F5 LTM use as its Source IP address to perform healthcheck monitors .
Hi F5 Experts ,
which IP does F5 LTM use as it’s Source IP address to perform healthcheck monitors ? Self IP or Floating IP ?
Regards , Chethan
  • @Nathan - Thanks for your reply . Can you please explain me why not we are using floating IP for Healthcheck Monitoring ?
  • Further to the original question: how does the BIG-IP select the health monitor source IP if there are multiple Self IP's on the same interface / VLAN?
    Is there a rules set to define this, and can it be manually set for deterministic monitoring?
    • PeteWhite's avatar
      PeteWhite
      It uses routing - ie it will follow it's self-IP/specific route/default route etc
    • dongill101_3435's avatar
      dongill101_3435
      Hi Pete, thanks for responding!
      I understand the self IP and routing options in terms of interface, but I must be missing something... If I have two IP's on the same interface that is also used for the default route, which one would it choose [out of the box].
      For clarity:
      • 10.1.1.8 and 10.1.1.10 are both "traffic-group-local-only" addresses on the same BIG-IP
      • Both are on VLAN1100 [called "DC1_LBNET"], Physical Interface 0.3
      • Default route is via 10.1.1.1 [default gateway] on interface "DC1_LBNET"
      • For any network that the BIG-IP is not directly connected to, and where the default route is used - which IP address will it use to source the Health Monitor / TACACS requests etc?
      I ask because I have just rebooted two BIG-IP appliances that have this configuration, and the health monitors were using say 10.1.1.10, but after reboot switched to using 10.1.1.8. The latter IP was configured after the last reboot to be used for BIGIP DNS but this was the 1st time it has been rebooted since.
      Am I missing something fundamental here?
      Thanks, Don
      PeteWhite
      I see what you mean Don, i've never come across that issue actually. My suggestion would be to do some testing to see which it uses and work it out.
    • newbie's avatar
      newbie
      would this be the Self IP of the VIP vlan or the server vlan?
      Thanks.
      _ Alex
      • zemkooo's avatar
        zemkooo
        Self-IP on the egress VLAN towards your pool member - if your F5 has a TMM route to it. It can even be a Management IP if you're missing TMM route to pool member IP/subnet - in that case F5 can use a route (and Src IP) from management routing table.
