Virtual server not accessible using 443 but working using the backend port
Hi DC Expert/All,
Does anyone encounter this kind of issue. BTW I am using selfsigned certificates.
Thanks,
-Nat
- Vijay_E
Cirrus
Is the VS listening on port 443 or on all ports ? Does telnet work to VS on 443 ? Can you execute curl to the VIP ? Can you provide the configuration of the VS ?
- Ryan_80361
Do you mean that for example if the pool member is configured to use port 4443 and you change the virtual server port to 4443 then it works? If this is the case, check that port translation is enabled on the virtual server.
- Nathaneil0227_2
yes it works even though if you access the backend directly.
Port translation is enabled.
-Nat
- Ryannnnnnnnn
Altocumulus
- Nathaneil0227_2
-Nat
- IainThomson85_1
Cumulonimbus
Going to need a little bit more information.
Presuming that you mean when you connect to the server directly, the page is working, but when traversing the LTM - it is not ?
We'll need a bit more information - VIP configuration, have you established connectivity ? A TCPdump/wireshark taken on the VIP and possibly client machine.
Regards Iain
- Nathaneil0227_2
Ian Hi,
Yes you are assuming it right.
And yes I had established connectivity.
-Nat
- IainThomson85_1
Cumulonimbus
Can you share your VIP configuration ? including all SSL Client information.
What error do you get on the client ?
- Nath
Hi All,
The issue is now escalated to escalation team of f5.
-Nat
