techie's avatar
techie
Jul 20, 2026
F5 XC WAF Automation for Bulk IP Prefix Blocking
I've a requirement to block more than 5,000 IP addresses in F5 Distributed Cloud (XC) WAF.
Is there any supported option to automate the creation or update of IP Prefix Sets using scripts or APIs, instead of adding the prefixes manually through the UI?
The goal is to automate the process of importing and maintaining the IP prefixes used for blocking traffic.
Thank you.
